MEP-805B Magnetic Speed Pickup (MSP) Missing.
dpTrail
Houston / Texas
I bought MEP-805B on GovPlanet and after spending lot of time trying to start up discovered the MPS is missing. I found an MSP on Green Mountain for MEP-805B which showed the MPN to be a GAC MSP6728. When I found EBAY and went to order it says the thread is 5/8-18 but when I checked the hole is much bigger. Tried to measure and looks like maybe 3/4-16. Is there sopposed to be some kind of adapter on flywheel housing to use 5/8-18 MSP?
Guyfang
25,907
Burgkunstadt, Germany
No. There is no adapter. Perhaps you should download the TM's for the MEP-805B.
MSP675C is the Part Number I see in the parts manual.
dpTrail
Houston / Texas
Thanks for the information on TM's link. Looking at MSP675C it appears to also be 5/8-18 thread. I am going to look at getting a thread insert to reduce the 3/4-16 to 5/8-18 to make it work hopefully.
2Pbfeet
1,172
Mt. Hamilton, CA
If it were me, I would try a 5/8-18 bolt before going too much farther. I can't count the number of times I was sure that I had eyeballed the size of a bolt, only to be off.
Is an MSP675C a compact version of an MSP675?
All the best,
2Pbfeet
