MEP 805B problems. Will pay for technical help
peapvp
1,226
Basehor, KS
This is not so much about getting paid, but rather the complexity of the system.
1. Is the S10 Dead Crank Switch currently in "Normal" Position and not in "oFF"?
2. When CIM has booted, does the Genset Crank when you place and hold the S10 Dead Crank Switch in "Crank" Position
If Genset Cranks via S10, then measure Voltage on J25-8 and on J9-3 for 24VDC to Chassis
If you got 24 V on these two connection then the Governor Control Module is dead and possibly the Voltage regulator as well
If you do not have 24V, then your A5 TCM-100 Board is partially working and needs to be troubleshooted by an expert onsite
This basically sums it up in a nut shell
Chad Lares
San Tan Valley, AZ
That gives me a direction. The next question is finding an expert if it goes to that way. Going to go look now.
Chad Lares
San Tan Valley, AZ
It cranks, just won't turn over. bad board?
peapvp
1,226
Basehor, KS
This thing clicking is your hour meter
Since the Green LED "DC Power" came back on, which is good, this is telling us that your Switch S10 Dead Crank Switch has an intermittent issue
Check and see if Genset starts now normally through S1 Switch using the normal procedure
peapvp
1,226
Basehor, KS
FYI, the dead crank test is exactly of what the name implies, a cranking of the engine without fuel delivery
The TM’s explain in detail of what this function does and what it is there for.
The S10 switches fail, the associated wiring harness can have fractures, burned and frayed wires etc etc
Furthermore, the cannon connectors connecting cubicles to Genset wiring harness can have corrosions, cold solder connections and broken wires etc etc
since I am not there with you, standing next to your generator, this will make the troubleshooting of your issue(s) more difficult
sofar we have made it to number 2 in our test list
this has now made the previous conclusion’s irrelevant since the DC Power Supply came back on
In general, there is no exact flow diagram in troubleshooting this issue.
my suggestion would be that you seek help from a local Genset repair shop in your area who are familiar with the MEP 805B / 806B
Our expert is located in Alabama and just returned from the Bahamas last week fixing Bravo units
he is going to be deployed to the Middle East next week
We have no customers in Arizona who I could contact to see if they could help you
Chad Lares
San Tan Valley, AZ
ugh, working on it.
Guyfang
23,961
Burgkunstadt, Germany
When a "B" model, (or any other TQG gen set) will crank, and not start, The first thing I check is the MPU. If it will not send a signal to the A5, then it is never going to start. Read the TM about checking, cleaning and darn sure how to PROPERLY replace it. Of you will be buying a new one. See if it is dirty, damaged or not adjusted properly.
155mm
Chief and Indian
388
Guymon, OK
Has the machine ever ran correctly?
where did you get the machine?
video of an attempted start?
like @Guyfang said, magnetic pickup.
Chad Lares
San Tan Valley, AZ
I'm still trying to figure this out. Nothing in the manual seems to cover why the Speed Control Unit doesn't get power.
Chad Lares
San Tan Valley, AZ
The cursor on the screen won't move anymore either. So I'm trying to figure out what I need to replace. I think it's the Speed Control Unit since it no longer lights up but I'm not sure if the MPU is in there or not.
