MEP002A Priming
mkcoen
382
Spring Branch, TX
Is there any work around on priming a MEP generator other than the fluid passage bolts on top of the filter canisters? I bought a couple out of Ft Hood and got one running without too much grief but when I went to swap filters on the 2nd I found that they had swapped out the original bolts with regular bolts. I haven't been able to find a source for these on line and need to find some way to bleed the system without them or scrap the unit. While the spin-on option is appealing I'm not really willing to sink that kind of money into it without knowing it'll actually run first.
Keith_J
1,328
Schertz TX
Oh, that is a problem for sure. Thought it was the bleeders on the top. Sorry for the confusing text..
Surely there is someone who has done a conversion to spin on that has these parts.
1,193
Live on the edge and bypass the filters and test the unit.
Then decide to invest later.
DieselBob
15
Arnold Maryland
I believe he is looking for item #2 in the diagram. It holds the metal filter can on and is through drilled and a pipe plug installed in the end.
1,193
I found it on parttaget. Should be easy enough to manufacture, if needed.
mkcoen
382
Spring Branch, TX
Thanks Bob. DH probably has the best advice. Worst case scenario is I blow it up and burn the shop down.
1800 Diesel
26
Santa Rosa County, FL
I could be mistaken (been occupied with other duties lately) but I believe I used to bleed the fuel system on my MEP 2 & 3 units without cracking the vent bolts on the housings.
Loosen/remove the hose or line from the inlet side of the IP and then run the pump until the filter housings are filled and the fuel runs steady out of the hose. Place the hose end into an empty 15/40 gallon jug or something suitable. Once you see steady flow with no bubbles, you're good-to-go for reconnecting the line & start up. Definitely would verify that the primary & secondary filters were in place. Do not recommend running the engine without fuel filters (used ones at least) installed.
Kevin
Trailboss
140
Norwood LA
You have 2 units - just borrow the bolts from the first unit to test the second. If it runs or can be made to run, I'd just buy the spin on filters.
rustystud
3,392
Woodinville, Washington
You should be able to bleed out the system with just the fuel pumps. Just turn it to "run" and then let the fuel pumps run until you hear fuel returning to the fuel tank.
mkcoen
382
Spring Branch, TX
The 1st unit was purchased for the inlaws and they're picking it up on Tuesday. I'd rather not take the chance of screwing something up where it wouldn't be running when they got here. I've been in the family for 23 years but that doesn't mean they wouldn't try and replace me.
Keith_J
1,328
Schertz TX
Kevin
that could work, the issue would be if the copper sealing rings are in place on the bolts. The fuel systems on these units are more often than not, disgusting. So running without filters is a very bad idea, unless you are willing to repair or replace injection pumps.
1800 Diesel
26
We agree on not attempting to run the unit without filters installed. Hopefully he won't do that. :)
Ray70
7,113
West greenwich/RI
I'm not sure if any fuel will flow through the return line if the unit isn't running, I thought the IP had to be going in order to get fuel through the return? I'd just prefill the canisters and loosen the line near the IP infeed , like 1800 said and let the primary pumps run. If you leave the canisters dry, expect it to take quite a while. the pumps don't push very much volume so it will take a long time to fill 3 canisters. Once you get it running any residual bubbles should work themselves out through the return line. Hopefully she's a good runner after that!
mkcoen
382
Spring Branch, TX
I got a bid on purchasing 2 of these bolts:
Line Part Requested NSN Condition Qty. Part Quoted Price Lead Time Line Total
1.
4730-00-861-6890 NS 2 4730-00-861-6890 $299.00 4-7 DAYS $598.00 Description: BOLT,FLUID PASSAGE Certifications: COMPANY COC
Quote Total:
$598.00
I think I'll probably pass on these.
rustystud
3,392
Actually if your pumps are working properly they will fill all three filters really fast ! If your pumps are operating slow, then you should take them apart and clean them up. They rebuild really easy.
