mep003a connectors
DaveB10
Hamburg, Pa
Hi! Since you have done so well in finding connector part numbers I am hoping you may have some advice for me. My MEP-003A was warming up "prior" to switching to house load when sparks started flying. In the ac control box/distribution box the heavy leads in P10 (7 pin male) from the generator to J10(7 pin female chassis mount) on the control box sparked and melted the connector before tripping the 40A breaker. I think what happened is one of the connector pins was corroded and heat built up till it melted the insulation between the pins...then sparks. I have a copy of the manual and no connector numbers are listed. It looks like major surgery to get to the J10 in the box. Any suggestions?? Even if I get a used control box I still need the plug end from the gen head. Thanks, Dave.
rustystud
3,389
Woodinville, Washington
You can also just buy the ends (that go into the connector) and using the proper crimper tool make your lines as long as you want . You just remove the old wires from the connectors (with the proper tool) and install your new made up ones in there place. We do this at work all the time when a wire gets cut or worn.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
You will need an Amphenol Part # 97-3106a-24-10s connector for the generator side of the problem area, can be had at Newark Electronics, Item # 92F5530
You will also need an Amphenol Part # 97-3100a-24-10p recepticle for the output box side of the problem area, can also be had at Newark Electronics, Item # 97J4589
