catienla
- 43
- 18
- anawalt,wv
MEP004 producing 87 volts on all three phases. Was 125 volts last time I ran it. Regulator rebuilt relay box repaired. Any ideas?
Are you still using the original exciter avr?MEP004 producing 87 volts on all three phases. Was 125 volts last time I ran it. Regulator rebuilt relay box repaired. Any ideas?
L1 to ground 87 volts, L2 to ground 87 volts, L3 to ground 87 volts. Across L1 and L3 154 volts.Where are you taking your measurements from?
Tried to run MEP004. It is only producing 87.5 volts on all 3 phases. Is there a way to adjust the voltage higher? When I ran it after last repair I measured 25 |
