- 17,892
- 26,785
- 113
- Burgkunstadt, Germany
Good, this old soldier needs to get to bed! Take care and Later!!!!!!!!!!!!!!!
Guy
Guy
One of the things I do is to take the return line at the tank off and put it in a container to see the fuel flow back through the system. It should be a nice steady trickle. You can easily see if you are getting a lot of air or if you have some other problem with fuel flow.Yes i did. I replaced most of the 3.5mm return lines. I will double check them and hardlines tomorrow.
