Midland Compressor never shuts off?
dansautosales
Diamond, MO
I recently purchased a 1971 M352A, Deuce and a half cargo truck. When I purchased it the air line from the block under the dash to the air pressure gauge was missing. I plugged the hole and that stopped the air leak. Now I noticed that when the truck runs the Midland air compressor runs continuously and never shuts off. The pressure keeps releasing under the truck midway back. My question is shouldn't the air compressor cycle in and out? And if so does it have a cycling switch? What would make the compressor run non stop? Thanks for your help.
rat4spd
10
Evansdale, Iowa
If the compressor is not unloading via the governor, and always pumping air, something has to give, and that would be the safey valve (pop off.)
