K5Cruz
- 0
- 0
- Earlsboro, Oklahoma
Warthog, it was a pleasure to meet you and your family, I can't say thank you enough for the help.
Got home with the fdc, installed it. Was missing the return line for the fdc, so I bypassed the fdc per instructions on here. Injectors don't seem to be getting fuel. Truck will start with short spray of ether, but I'm not too big on using it.
In tank pump is missing plug. Fuse seems good, pump isn't obstructed. Plug to pump is missing. Found wiring diagram to pump, but no pictures of plug. Would it be possible to run jumper wire to pump to aid in priming system? Where is it grounded, off the prong I assume?
Pulled the center bolt out of the hydraulic head per a post on here to make sure plunger was free, verified with piece of vacuum hose that it was indeed free. Pumped quite a bit of fuel out of hole. Plug was extremely tight, sheared 3/8 extension trying to remove, had to step up to 1/2 breaker bar.
Been at it all night, fresh fuel in the tank, fresh fuel in the filter housings. The only thing I can think is the system won't prime without the in tank pump. Any ideas? Sent from my phone, sorry for any spelling/grammar errors.
Thanks.
Thanks.
