mod five tonner rims
stagehc
I know this thread has been started but....
just for the record, can you slice out the center of 2.5 tonne rim and weld it into a 5 tonner super-single and then hack out the superflous middle section?
cheers from over here,
cole
40grit
bryan,tx
I had looked at water-jetting a center plate, with the 5 ton beadlock patterna and the 2.5 stud pattern, sandwich that between the 2 halves and bolt down, cut off the 5 ton pattern and you have some 2.5 ton rims, I had planned on 1/2 plate, widens the rim to 10.5" but no welding or chance of warpage..I'd try this with the older rims that had a bunch of bolts, not the newer ones that have 1/2 what the others did...somewhere spicer has pictures of the rims I was looking at...
stagehc
Looks Like I wont need to go through all the drama. Here is a pic of a stock 2.5 tonne rim with a 395/85 XML stuffed on it. I was always taught you could use a narrower rim, but not a wider one.
Cheers from over here!
Cole
