More Filter Questions?
mtech
Clinton/Iowa
After spending several hours searching old posts and seeing all the discussion on oil filters for the deuce/multifuel, it is obvious that many have problems with the filter set up. The specific problem that I have encountered, since the temps have dropped below freezing, is the front filter now leaks about a quart until the engine has run for a minute and then seems to seal itself up. Is this one of the common problems?
Josh
