av8or
- 4
- 18
- fort denaud, florida
Bead locks or run flats will let you limp to a safe spot, will allow you tom air up a flat as the bead will not break, and make airing up when mounting much easier. Bead locks for 1400r20s are 7 3/4" wide maybe a shy 8" on some, 1600r20s have 1 1/2 " beads which are thicker then 14s and the coresponding bead locks are narrower 7+ " not sure if thats + 1/4", + 3/8s" depending on brand. Would like to know what others have found! A 1400 bead lock requires almost 1" of compression which is real hard on bolt threads and deforms the bead lock badly but will work. If anyone has any bead locks I would like to know what their's measure. 1400 & 1600
