mpe803a
kloppk
4,172
Pepperell, Massachusetts
Did you hook my VR's wire back up to K15-1?
Frequency is set by adjusting the Frequency Adjust throttle cable located on the far left as you're facing the control panel. Recessed black knob. unlocking the knob and turning it will adjust the frequency (engine RPM).
mchlsprgn
14
jamul cal
yes
kloppk
4,172
When you start the generator and hold S1 in START is the correct AC voltage displayed on the generators AC Voltmeter? What voltage does it read?
Once you release S1 back to Prime/Run does the AC voltage displayed on the generators AC Voltmeter drop? What voltage does it read?
kloppk
4,172
Normally you can adjust the frequency a few Hz below 60. You'd need to post up a picture of the mechanical governor lever so we can see if it's a cable problem or an adjustment issue with the mechanical governor stops. Normally the stops are set at the factory and don't need adjusting.
Post up a picture when you have a chance of the mechanical governor lever and the stops.
mchlsprgn
14
jamul cal
yes it drops to 0 sodoes the hertz ,about 200 volts
kloppk
4,172
Make sure the wire from my VR labeled M7-I is on the correct terminal on the Oil Pressure Gauge.
It should be on the "I" terminal, not the "S" terminal.
mchlsprgn
14
jamul cal
[/ THAT DID IT!.. MY OIL GAGE IS OPPOSITE OF THE PICTURE NEEDED A MAGNIFING GLASS TO FIND I TERMINAL
HERTZ HAS LOTS OF AJUSTMENT SO DOES THE VOLTAGE I'M STOKED THANKS FOR YOU PATCIENCE MIKE
