Muffler madness
Capt.Marion
15
Atlanta, GA
Re: RE: Muffler madness
GunnersHusband said:
holy poop that's big....... let us know how that works out for you. I'm considering that upgrade myself.
Mufflers are nice. You can have conversations in the cab whilst driving... and even going up a grade.
5tonpuller
24
Thompson, Pa
RE: Re: RE: Muffler madness
Mine is all done. I need to get my pictures together to post. I set mine up to ether use the stock stack OR the muffler. I think you will like it.
m52a2
Jackson, Michigan, USA
The muffler is a great idea, I used a racing muffler from Jegs high performance to keep is low profile. just be sure to use high temp paint ! what you see is the brown promer not rust. Now I figure to let the paint I used burn off and then apply the high temp kind.
m52a2
RE: I just finished mine!!!
to address fhoto of m52a2 muffler & fording kit stac: As part of the fording kit on the 5 ton multifuel, the small steel virtical pipe next to the air cleaner stack is air system vent from the firewall manifold kept seperate from the air cleaner stack, also there are 2 flexable hoses, one from the compressor and one from engine crankase vent that tie in to the air cleaner stac.
FreightTrain
Banned
2,730
13
Gadsden,Al
same for a deuce.One rubber hose hooked to the slobber tube that dumps out under the shroom on the rubber intake snorkle,another rubber hose from teh compressor to teh boss on the filter can then some misc junk to mount it to the stack and to run air to the bell housing.
GoHot229
Almost done!
I used that same muffler and the 'whistle' comes through plenty good enough to be heard, I dont think I'd want a Duce to be unmuffeled, as it is my next step is to Tractor Supply for some of the rubber flooring mats they use in horse trailers and will cut to fit the floor and firewall to sound deaden the noise factor.
