multifuel "C" turbo on M35A3 ?
4,674
Seems to me you're putting lipstick on a pig so to say.
The C and D turbos are archaic in design. You're also asking a old turbo meant to support 135hp to substain 170hp. It could probably do it. But I'd look towards a more modern turbo or a cat replacement turbo before going down this path.
JasonS
131
Eastern SD
Can you give some details about what makes them archaic? The "d" isn't THAT old.
3dAngus
101
Perry, Ga.
I think it would be darn cool to have the first whistlin' A3. Go for it Steve! Then take us a video with good sound. I want to hear it. It would be a good Utube project.
3dAngus
101
Perry, Ga.
If you are going for the sound and the a3 doesnt do it for you just cut the pipe and weld on a a2 pipe. Theres a few scrappers down there that will only get scrap value fot it.
4,674
Ummm yeah, they are. You've got to consider they've been around for 30+ years. Turbo design has came WAAAAY ahead since then. The latest hot thing in turbos are "batmowheels" as they're nicknamed. It know it looks like a damaged wheel, but the blades are actually "waved". It gives a lot more surface area making a 60mm compressor outflow a standard 60mm with no mods other than the wheel.
A modern S300 or 400 borg warner turbo certainly would outflow the C or D turbo.
BTW, the D turbo flows more than the C turbo.
4,674
Doh, so you're going after all this for sound only?
Yes, ditching the muffler will certainly get more sound of it. Removing the air filter and using a cone element will also increase it as well.
I'm of Gimp's mindset though. Loud turbos get annoying fast.
