- 1,079
- 58
- 48
- New Palestine Indiana
removed
Which is why the ending prices on GL are always going up. People have no idea what they're getting into but bid away..
We have been involved in a desert war since that truck was new, it's painted tan, just sayin'Well I joined the ranks of MV owners this week with my purchase of 2 trucks and 3 trailers. However on the way home with the new 5 ton flat bed I had several bad problems. The most notable are it is stuck in low range, will not go over 20 mph, when the shifter is shoved very hard it will go down like it is in high range but it just sits there and makes a light grinding noised when put in gear. So I had to drive it to my friends shop 6 miles away at 20mph.
Then when I turned left into his shop the front rear axle came loose and twisted up under the truck into the fuel tank and leaf springs. Also the batteries were dead and disconnected and the brakes were jacked open and an air line fitting was broken off. With 1200 miles I thought it would be like new and ready to drive around only needing fuel, boy was I wrong.
Is this normal???
I thought these things were near indestructible and I can't even make it 6 miles with it driving easy without it falling apart.
How can this be fixed?
The other truck I got has 59 miles and is a 5 ton dump truck, it does not run and who knows what I will find wrong with it.
Why do the axles fall off when you turn left too sharp?
What the heck would I have done if I was surrounded by zombies when that happened!
I usually use that same gate most everyday going back and forth to work. Thats the gate I drove the trucks out of and then down across the bridge to my buddies shop at the foot of the mountain on 231. Next time you go by there you'll probably see my new trucks sitting there waiting on TLC. Let me know when you going to be there and maybe we can catch lunch, I'll buy if you'll share some knowledge while we eat.I come in off 231 by the Wally-world.
Was it the Redstone GL crew that shot you the line of BS about the truck's condition? Doesn't sound like them.I usually use that same gate most everyday going back and forth to work. Thats the gate I drove the trucks out of and then down across the bridge to my buddies shop at the foot of the mountain on 231. Next time you go by there you'll probably see my new trucks sitting there waiting on TLC. Let me know when you going to be there and maybe we can catch lunch, I'll buy if you'll share some knowledge while we eat.
Oh, and I promise no more short low speed hauls over 20K, at least not if I can help it.
