FatBuddhaBoo
- 8
- 18
- Jacksonville, Fl
Cold and windy day here in NE Florida. Didn't get as much done as I wanted before the rain started, but progress nonetheless. Welded two inside lower cab braces which really helped reduce flexing and plan on adding one towards the top as well. Got the cab cross member fitted and re-installed and put a few beads of weld on the back cab floor to hold it down. Still have to source some metal to finish the rear cab floor, but still have lots of other stuff to do before I really need to start worrying about it.
![cab mount.jpg cab mount.jpg](https://www.steelsoldiers.com/data/attachments/282/282857-d4e70738fecab86734b57fe3961e4b1b.jpg)
![inside weld 2.jpg inside weld 2.jpg](https://www.steelsoldiers.com/data/attachments/282/282858-7def9a2a79a1f57fe3fd30a3fb58aaf6.jpg)
![inside weld 1.jpg inside weld 1.jpg](https://www.steelsoldiers.com/data/attachments/282/282859-796d82160a5316dbaa4a5d267e94228f.jpg)
Added a few more things to the list of items to repair: oil pressure gauge intermittantly doesn't show pressure, as well as the brakes having leaked down again (which I believe is from the driver's side center brake cylinder based on the fluid leaking down the tire).
![Tank :tank: :tank:](https://www.steelsoldiers.com/images/smilies/tank.gif)
