My M109a3 going 100% LED
Darwin T
12
Port Arthur, Texas
2 light the panel, 1 for high beams, 1 for transfer case, 1 for turn signal switch, and mine has 1 in the middle for low air pressure warning light. there is a link in post #5 for the bulbs. they come in red, green, yellow and white. they also come in different voltages so watch out. i bought white and used the covers to change the colors that way i can use any bulb anywhere.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
How many bulbs light up the factory gauge cluster for the gauges? I want to upgrade these to LED as i cant read the needles at night
What part number
Have you pulled the gauge cluster and cleaned the windows on the side of the gauge that let the light in?
Darwin T
12
Port Arthur, Texas
the back of my dash gauge cluster is the same color as the front. if i remove it again i will paint the back white or something shinny. i also am using see through covers on the dash to have a little cab light, not for a work light but just to see if i have to grab something. the covered covers don't shire outward and make the gauges briter. all of my gauges were replace with new ones about 2 years ago. i can see the gauges better than my cell phone camera can.
i think it works really well.
srodocker
70
Lacey, Washington
Now where did you pick that blackout light that is awesome! i have to order my dash bulbs soon. i wonder what the life span is and how many i should order...
jstier
13
Fort Wayne IN
I found a set of LED headlights for a good price, They are on the way.
The Blackout light looks sweat. **** now going to have to find one.
Jeff
Fort Wayne IN
1986 M923A1
Darwin T
12
Port Arthur, Texas
the LED blackout light i bought on Ebay and i had to order two and it was pricey.
the dash bulbs the is 1 in the turn signal twitch, 1 hight beam, 2 to light the gauges, 1 in the transfer case air switch and if you have a low air warning light then one more.
5 or 6 will work but i order a couple of extra. i don't know how long they last but LEDs usually last longer the bulbs.
CobraCDR
Twin Cities, MN
The LEDs are suppose to last 10x-50x times longer than a standard bulb and are far more resistant to vibration. The justification for the replacement cost in them is that you should only have to replace (or switch over to them) once. I have yet to see any burn out or fail.
Darwin T
12
Port Arthur, Texas
well got the LED front turn signals mostly installed. everything was going great until, wait for it, the passenger side one would not blink, the very last light go figure. the blackouts work fine but no flasher or turn signal on the right side front, back works fine. i tried 2 different lights and the same thing. i think i have a grounding issue, i hope that all i have is a grounding issue. run out of day light. so i will call it 95% LED. the last picture is the headlights in action.
