My M135 Quad cab
m1010plowboy
2,977
Edmonton, Canada
Looks factory because it is factory. Thanks for the pics.
Your air-tank location and fitting picture somehow got me thinking of a couple of mini air-bags in place of the springs. Can't believe I'm talkin' like that,,,,,
To keep these trucks all in one place one of our brightest M211 builders started this thread,,,, http://www.steelsoldiers.com/showthread.php?58040-The-unofficial-g749-picture-thread!!!!
.......it would be very cool to have some pictures of your truck in there when you have time. Greatly appreciate the pictures.
JerseyHick
Cherry Hill, NJ
Park-Break mount;
Mount is 5.5'' hi off the floor. At this height you wont even have to readjust your linkage.
Fabbed mine using an old jeep bumper i had laying around. Not happy with the look, but near the end of the build, i was getting lazy.
If i were to do it over i would use 5.5'' channel or 1/8'' plate. That will 100% cleaner than mine.
JerseyHick
Cherry Hill, NJ
PTO/T-Case lever mount;
Simply mount it directly to the floor, then readjust the linkage accordingly.
Bench Seat Legs were made from the discarded rear cab corners..
Trying to keep the ''Could Have Came From The Factory'' look.
Have a few more ''speed bumps'' i ran into ill post later.
Hope this helps the next builder... Common guys.. I don't wanna have the only quad cab!:)
hendersond
31
Galesville, WI
Yes, it looks great. I keep trying to find a flaw, but cannot! how did you do the channels under the cab? The ones that run from firewall to back of cab just under your feet. I'd say that was the hardest part for me with the height change. I may even do it over. I have a junker that is going to donate some new channels so I can re-work it.
JerseyHick
Cherry Hill, NJ
Just USE the height change... the front cabs channels will sit on top the rear cabs front body mount channel.
When i disected the donor cab. I kept the hole floorpan and channels intact, all the way foward to rite were the floor starts to angle up under the dash, cut away floor there. Cut the channels there to. That means the furthermost front body mount channel, that the factory cab mounts bolt to, is still intact.
That way when the rear cab is butted up to the front. The front cabs channels, that are now raised in the rear, will sit perfect on the rear cabs body mount / cross channel.
Sorry i know i didnt explain it very well, i think i confused myself!
One look @ the pics and you will figure it out.
hendersond
31
Galesville, WI
So, what you are telling me is to do this.
Of course, I should cut it off straight...
I guess I was overthinking it. I had it in my head that I needed to cut the dog leg out and weld a straight section between the two.
I have been jacking around, hung up on that, trying to find a piece of cab channel for a year.
Thanks, you just helped a fellow SS member. :)
m1010plowboy
2,977
Edmonton, Canada
I feel like I just checked into the G-749 Surgeon's website.
YA did it again Dr. Jersey, a little flicker of a picture on a modified tailgate in the 'unofficial G-749' thread and with it being Christmas.......when you get a second can you share a little detail on my present, a modified tailgate, please. Looks like you cut out a section for a roll-over, flip down grannie step.
We know that most future tailgates will need to be re-created so having a useful modification is just good planning.
With the experience you and the 2 Henderson doctors have, do you gentlemen think this can be done so it is "reversible" on the primary cab?
I'd love to have one but I have a few original trucks that deserve to be saved although they want more riders in the cab right now.
A bolt up cab-kit and after-market, shortened box and your tailgate could be attractive to a growing but small G-749 market.
Can the surgery be engineered to be reversed?
JerseyHick
Cherry Hill, NJ
Thats the factory tailgate, as it left the factory. I believe drop-down gates were only on early m135 models.
It is pretty sweet tho!
You could fab one out of a standard gate. Wont be to difficult, its a simple mechanism.
Ill post detailed pics and measurements if you want.
My cab is welded, so I cant reverse mine.
The cabs will actually bolt together, that was my original plan.. Olny problem is you would have about a 6.5'' space between the doors. I really wanted as little space as possible, think mine ended up at 3.25''
Seriously tho...DO IT!! Im really curious to see how it would turn out.
hendersond
31
Galesville, WI
Dr. Hick, you are a brilliant man. I ended up with exactly 3-1/4" between the doors too. I did not look at landmarks, just what I thought was visually attractive. What are the chances?
1,161
I just noticed the turn signals. Clever.
I am a purist (for the most part) but I love this thing.
hndrsonj
Senior Chief/Moderator
377
Cheyenne, WY
Let's see some pics of the early tailgate. I'm guessing most have never seen one!
Gunfreak25
620
Yuma, AZ
First class job, very glad you had the "guts" to post this. I would certainly consider doing it with the M211 6.2 project had I an extra cab laying around. There are enough of these trucks around that have been restored that customizing a select few for the purpose of obtaining the maximum of amount of entertainment from said trucks is justifiable.
You seriously going with the 454/Th400 in the spring? Excellent. Have you considered building a 700r4 for the truck to make it even more highway friendly? Or is it a dedicated street/offroad rig. Even then, the 3.06 first gear is great.
