lonesouth
- 29
- 28
- Tallahassee, FL
Switch would reside inside the right access panel with one side wired to the main lugs of the MEP and the other side wired to a 30amp generator socket. I looked at the one you linked, but the MEP can run 66amps, so I'm going with a 100amp switch. Your switch would be fine if I were wiring it up independent of the MEP, but since it needs to handle the 4kw portable and the MEP, I need to size it for the larger source.
outside 30amp twist lock socket
https://www.amazon.com/gp/product/B000BQT47S/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
