My new 1992 M998 Avenger
springer1981
1,184
Maine
Pretty dang amazing that you found those dataplates...
AND that the seller was willing to help with the second plate!
The guy mentioned he had 3 Avengers... as it turns out he has another set of data plates and they are now listed on ebay. He probably realized someone might be looking for them after I said I bought it just for the data plate. I am really lucky he threw in the other one as well. I am also lucky that the set I ended up with are in much better condition than the ones listed now. That said I would have been just as happy either way as having them beats not having them.
Here's mine compared to the ones listed now. There is a slight difference in the weight and balance plate, earlier vs later I suspect. Also the wear on the serial numbers etc.
Here's the current auction picture...
FlameRed
656
Florida
I was asked about the TPS sensor I used in my 4L80 conversion so I took a couple pictures.
I used a Standard TH160 TPS sensor that is a very common GM TPS sensor. For reference of the location, the first picture shows where the TPS sensor gets located. The connector just above the arrow is the TPS sensor connector and wiring that I ran into the cab to the Quick4 TCU.
You must first remove the Fan Cutoff switch and cam from the shaft.
I am just about at the point of installing the TPS on my 4L80 conversion. I wanted to ask about relocating the Fan Cutoff Switch. Might you have any pictures on where / how you relocated the Fan Cutoff Switch?
Retiredwarhorses
4,633
Brentwood, Calif
fan cutoff switch moved to the throttle bracket as done on the turbo trucks or moved to the rear left head as done on A2 trucks
springer1981
1,184
Maine
The truck ran great all year. No leaks, no issues and starts right up. We have some snow coming (not much) and that signals to me it's time to put the truck in the garage for the winter. Not that it can't take the winter but so I can keep working on it and moving the project forward.
My garage is less than 1 mile from my house and first thing I notice is the volt meter higher than normal. It has never been anywhere except on the white line in the green area (Red Arrow). Today it's running in the Red area!! I parked the truck for a few minutes and when I came back, antifreeze under the truck!! Leaking like a Siv.
I drove the last mile of the year and all hell breaks loose! (ok not that bad but....WTF) :confused:
As underlined above, my truck started leaking as I was putting it away. Today I got under it to see where it was leaking from. This was a brand new hose, found the original seller and I believe it was NOS. Probably 30 year old surplus. EDIT: It was 18 year old surplus.
springer1981
1,184
Maine
Pulled the hose out today. Snapped a pic while I was under there. When I replaced all the hoses I also replace the metal cooling pipe as the original was all rusted. Found a "Stainless Steel" replacement and used it. I know stainless means less not stain proof. However there are many different grades or alloys of stainless. This doesn't seem all that stainless and probably should be called "Stainmore". 😂
springer1981
1,184
Maine
Back on this post https://steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2481048 I mentioned when I was putting my truck up for the winter, the last mile of driving for the year, my generator went up on the charge voltage. Picture of the high reading in that post.
Today I tested everything to determine if it was the generator or the regulator. I attached the test procedure PDF below. After following the flow chart it indicated the regulator was bad. I replaced the regulator and it seems to function different than the original. The regulator that was in it always sat dead on the ideal line on the gauge. It never fluctuated or moved until it went high. That regulator was dated 2006 manufacture. I believe that regulator had been there since the repower of the truck in 2006 with the GEP 6.5.
The new regulator sits higher than the mark on the gauge but not in the red. It also starts of low and slowly comes up to charge. I did read the regulator was designed to ramp in the charging over a 10 second period so as to not overly strain the engine on start up. This one also varies with throttle. If you give it throttle and stays pretty still but if you tap the throttle and bump up the RPM's it will spike the gauge into the red and quickly settle back at normal.
I question if the new one is not working correctly or if it is just a different design and is working correctly. Time will tell but unfortunately when it does tell it will be because my batteries got wrecked by it.
Coug
4,830
Olympia/WA
Don't trust the gauges.
Using a multimeter, what voltage are the batteries reading while all of this is happening?
springer1981
1,184
Maine
Yes and no.... gauges aren't always accurate but they mostly preform consistently. Also analog gauges show stuff digital gauges don't. A digital gauge samples and displays a mean average over time. A slight variation is often suppressed in a digital gauge. My digital VOM (Fluke) meter does this as well as all other digital meters. The dash gauge is analog and reacts no matter what is thrown at it. My analog gauge on the dash has been rock solid for 4 years of driving my truck. It never moved from the nominal line on the gauge. Now with a new regulator it clearly reacts different as shown in the video. It shows what you wouldn't see on the DVOM. For this reason, one of the best meters you can use is a Simpson Model 260. In this case, it isn't about the number on the meter as much as how the meter is reacting and showing what the regulator is doing. The dash gauge does this perfectly.
To your point of the batteries, the batteries act as a capacitor in a way since they store energy. They store so much energy that spikes are smoothed out. the analog meter will show those spikes and DVOM wont. The batteries read correct voltage with a DVOM but that doesn't negate what the regulator is actually doing.
Coug
4,830
Olympia/WA
all true, but I'm more concerned about what the actual voltage is at the batteries with the gauge sitting right at the top of the green. If it's 29V or below, then the little spikes up above that shouldn't be of particular issue. If it's above that, depending on your battery type, you might need to check and add distilled water more often (if flooded lead acid and non maintenance free type) or much higher than that would tell you that the regulator is not acting correctly before you fry your batteries.
Also to comment, just because the gauge has behaved the exact same way for 4 years doesn't mean it's reading exactly where it is supposed to, and the old regulator might have been producing lower voltage.
But yes, I definitely agree if the gauge is acting differently than normal something is up and needs verified.
springer1981
1,184
Maine
First, thanks for the input. I appreciate all comments, suggestions, different points of view, etc.
I did check the charging but while working on something else (next post) I checked it again and took some pictures. It averages between 28.14 and 28.49 VDC on my DVOM. The analog meter still works as described before and seen in the video.
springer1981
1,184
Maine
So today was the day to finish the light switch modifications started here https://steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2460891
In the thread there was some discussion about leaving certain circuits "powered up". My thought process was to use the "Run" circuit from the ignition switch to power the necessary circuits for typical motor vehicle operation when you "start up and go". That said, I was going to supply that additional power circuit using and unused pin on the light switch connector, Pin L. Turns out the factory light plug is molded and Pin L isn't accessible to tap without cutting it off and replacing it completely. The red arrow points to where Pin L should be.
Rather than use Pin L, I had an old Fuel gauge and I removed one of the terminals to use. I purchased a nylon spacer from a local hardware store (red arrow below) and I drilled a hole in the back of the light switch. I turned it down so it would insulate the terminal from the metal housing.
Here it is after I completed it.
I made a "Y" connector to tap the "Run" circuit and supply power to "Pin L" (now added power connector), then I tested all switch functions. It functions as expected.
With ignition off, the light switch can be set to running lights and headlights but directionals, brakes and horn will not function.
With ignition in Run and light switch off, directionals, horn and brake lights all function. Basically "get in and go" and all the primary functions work.
With ignition in Run and all primary functions working, the light switch can now be turned to "Running lights" and then to "Running lights and Headlights".
The alternate method, not using an external power source would allow all the brake lights, horn and directionals work at anytime regardless of the ignition choice, ie Run or Off. I didn't take a picture of it after install but it is installed now.
springer1981
1,184
Maine
So it's been a while since I've done an update. Life happens, you know the deal. For the most part I haven't done much other than drive it and some regular maintenance. Well that is until recently anyway. About 4 weeks ago I heard about military vehicle meet going on in a nearby state, in a town I grew up near. I decided I wanted to go so I called and got a campsite. 162 miles (4 hours) each way , staying off the interstate highways.
I needed some place to sleep and worst case scenario I thought I would by a tarp and throw it over my truck and sleep in the back. So I bought a nice $160 Olive Green Canvas tarp and $40 worth of 3/4" conduit to make bows with. Then I started looking around to see if I could find an Upholsterer that could help me fit the canvas better than throwing it over the top. I found a guy and explained what I wanted and he said he could help in October. I said I needed it 3 weeks and could he help. I over simplified what I needed saying I needed like 4 seems done and he said he would give me a Saturday, July 19th. I proceeded to figure out how we would make a top. Oh yeah, I forgot to mention that I convinced him to let me help.
I went looking for what tops used for hold downs on the truck and found little plastic clips and straps. They were pretty expensive considering I needed 15 of them so I looked for alternatives and found surplus fuel can hold down straps for $5 each. I also spent the next 2 weeks figuring out how to 3D print some grommets of sorts to use with the straps.
July 19th, 8am to 10pm (14 hours), this is what we came up with.
Tarp rough cut to size
Tarp fitted, corners sewn and hemmed to length
Fuel can straps sewn on
Top done and zippers for access in the back
springer1981
1,184
Maine
With the top done, I proceeded to make it into the smallest RV by adding a bed to it. Bought an Amazon memory foam twin size Mattress in a Box. It was a little too wide so I took it all apart and cut 3" off the side. I carpeted a piece of plywood to put down on the truck bed first and put the mattress on it. I notices it was very hot in the truck with the canvas top so I picked up some reflective insulation from Home Depot and lined the inside. It worked very well.
springer1981
1,184
Maine
In the 3 weeks leading up to camping in my HMMWV I also wanted to tackle some of the other projects I never got to. One priority project was Door Locks! I've contemplated the replacement locking door handles but I never really liked them. Reminded me too much of file cabinet locks. Please who wants to go around to each door and lock or unlock the door with a key every time? I have been considering this issue for a few years and finally came up with my solution, Electric Locks. I think I'm going to offer these kits for 2 and 4 door X-Doors. One of the goals was for the doors to still be easily removeable. Another goal was simple to install and not be hideous looking.
Here you can see the locking actuator.
Here is the quick disconnect Cannon connector. You can see the Key FOB just under the direction switch.
springer1981
1,184
Maine
Back on Page 12, Post 231 of this thread HERE I mounted the US Shift Quick 4 TCU in the dash in place of the air filter gauge. The plan was always to create a bezel for it to match the rest of the gauges. Now that I have a 3D printer and started learning how to design parts, I came up with this. I probably printed 20 versions and put about 40 hours into it, painted a handful and broke 6 45mm watch crystals until I got it right. It had a little extra space to fill so I added "Avenger" to it. Also put in a Cell Phone holder.
The TCU gives a lot of useful data. What gear the transmission is in, tranny temp, lockup status and MPH as well as many other things.
Gcelevator
806
Fort Lauderdale, Florida USA
I can say, that came out pretty nice. 😍
  • Like
Reactions: D6T
springer1981
1,184
Maine
Everything you Never wanted to know about your Coolant Temperature Fan Switch.
Basic HMMWV Operation. It supplies power (24v) to a terminal on the Time Delay Module. When the temperature exceeds a specific set temp the switch turns OFF. This engages the fan to deliver more air flow to the radiator. When the temp drops below a specific amount, the switch turns ON. This disengages the fan. (more about this below)
Electric Fan Operation. The above is basically the opposite of how electric fans. In a switch controlled electric fan, the switch turns ON to start the cooling fan and then turns OFF when the temp drops enough that it no longer needs the fan.
The difference between the two is the HMMWV fan uses a temp switch that is "Normally Closed" or "NC". The standard electric fan switch uses a "Normally Open" or "NO" type switch. In the process of looking for an alternative replacement fan switch, this is extremely important.
The Problem. Many cheap Chinese temp switches do not operate at the correct temperatures. Finding NOS switches or quality switches is not easy or cheap. I personally have been fighting high engine temperatures related to the fan control system. I have rebuilt my Fan Clutch, replaced the Time Delay Module, replaced the Cadillac Valve and nothing has helped yet except unplugging the Time Delay Module OR the Temp Switch and that forces the fan to be engaged for maximum cooling.
Disconnecting the Fan Control System is a band aid and works well in my experience HOWEVER there are disadvantages to doing this. The biggest issue is it uses precious Horsepower to drive the fan. If deep water Fording is a concern then the fan has to be able to be disengaged so it will stop turning in the water. If the fan was to stay engaged it would likely damage the fan clutch, fan blades or the belts. For these reasons it's desirable to have a working Fan Control System.
Basic Fan Control System Operation. The key to ALL of the above is the Fail Safe. The Fan Clutch is defaulted to engaged. The temp switch, time delay module and Cadillac valve are all points of failure. All these items are used to Disengage the fan clutch. If any of them fail, the clutch returns to default (Engaged) forcing the most amount of air cooling to the engine allowing it to keep running in most any condition. However there is one flaw to this, the temp switch that fails to turn off at the correct temperature thus causing the fan to remain disengaged resulting in over heating.
The cause of the problem IMO is cheap temp switches. I replaced my Original switch with a New Old Stock (NOS) "Made in USA" switch. Unfortunately when you search for the part on Ebay or other places and price shop you will find them for $30-50. These are cheap poor quality switches with little or no quality control and vary widely in temperature range. When you find a Quality USA made switch it will cost roughly 4 to 6 times as much. NOS runs over $100 and NEW is $170+. Anything less than 100 is most likely JUNK.
How to identify Quality from JUNK. First is cost, as mentioned above. Second, is more generic packaging. Cheap plastic bags vs heavy labeled plastic bag is a red flag. Tags on the wires with part numbers and manufacture identification. I've also noticed the length of the smooth (sensor) part seems shorter on the cheap junk. On some the threads go all the way to the hex. When you know what to look for, the cheap ones really stand out.
I set out to look for an Alternative Temp Switch and the first hurdle was the "NC" vs "NO" switches. ALL the switches for electric fans are "NO" and we need "NC". The second hurdle is correct thread, 1/2" NPTF. The third hurdle is operating temperature. I found what I believe to be the perfect replacement. It's actually a large truck diesel engine switch that has Both NC and NO contacts. The temp range is 195F and 1/2" NPTF. However these suffer from the same issue, many are cheap JUNK. It's easier to find one of these quality switches at a reasonable price than it is NOS or NEW HMMWV replacements. To use on HMMWV, cut wires off old switch. Put properly sized crimp terminals on wire ends and solder. Also use Marine shrink tubing to seal the connection to the crimp terminals. Install the new temp switch then hook up the wires. If the new switch has 3 connections, use the "C" (Common) and the "NC" connection to attach the wires to. If using the Horton switch it's only "NC" and only has 2 terminals.
Disclosure: I have one of the Alternative Switches on order but have not tried it yet. I will update when I get it. In the mean time I'm testing my NOS replacement to see if that solves my issue. I'm 99.9% sure the alternative will be a great option for a reasonable price.
Here is a list of Quality NOS or Surplus part numbers and manufactures to look for. The Cage Code is KEY.
Example of a Quality Part
