- 34,012
- 1,806
- 113
- GA Mountains
Yes but remember, it's only a long block which means basically its from the complete cylinder heads down. No intake, injection pump, turbo, exhaust accessories and the like.
If you don't use the serpentine setup you HAVE to change the water pump - they are reverse rotation over the belt setup. Basically your looking at all new accessories and mounting for belt vs. serpentine. I'd stick with the serpentine - it's a better system and a higher flow water pump - it's also current.That hole you see is a water drain hole for the valley which sould be hooked to a tube that exits the side of the block in the back. that engine will work for you, if don't us the serpentine belt system, I think you will have to replace the water pump, the bolt holes for the old pully will not line up. The only thing you will not have is your fan cut off switch, cause the tps is mounted in its place. but you can install one on the throtle cable side. Other than that it will work and is a much better motor.
