My new Baby
20,760
New to the site here is my girl
Welcome to the outfit!
Looks like you have lots of wide open spaces to "go play truck"!
As a new member, be sure to go to the Technical Manual section and download the TM's.
Those are really handy when you need to know what wire does what and how to cover all the grease fittings, oil and filter information.
The list goes on and on. SEARCH in the TM's are your friend. Figuring out the terms takes a bit, but well worth your time!
Dino68
Arizona
Thank you I really appreciate it
Bill Nutting
1,364
Chesterfield, Mi.
Hi Dino68. Welcome to the site. You will find a lot of information and helpful, friendly folks here. You have a nice looking truck there. I'm curious, did you have any issues getting it titled? Some states (like Michigan) make it almost impossible.
Dino68
Arizona
Hi Bill
Thank you titling in Arizone was a breeze took in thr SF document and got a tile in and out in 10 minutes
Phoenix77
545
Greenville, NC
I have a 1986 AM General M998. I did initial fluid replacement (oil change, coolant flush, transmission fluid, changed fuel filter), installed two (2) new batteries, then the only other issue with the truck was what I surmised to be clogs in the fuel lines.
I had the tank pulled by a local shop and they cleaned it out and flushed the fuel lines. They said the mesh "trap" for foreign objects was COMPLETELY full of mess, and there was water etc in the tank. $400
After that, changing glow plugs a few months ago, and putting a few tanks of fuel through it with injector cleaning additive, it's running GREAT; significantly quicker than before.
Oh, and I replaced the rear diff, but I attribute that to being driven on base on high traction surfaces in HL it's entire life.
Do your due diligence initially and expect some frustration, but disregard the "1 hr drive, 2 hour maintenance" comment; these aren't boats.
