goldneagle
- 1,453
- 113
- Slidell, LA
The plan designer did include a propeller assembly. He has it placed a bit high. I will place it as low as this model allows. I am also redesigning the winch in the back. I will notch out the back wall for the proper winch install. I am making 5 bows for cargo instead of HIS 4. I will build an inner tub for the cage area. Also a suspended floor in the rear winch area..
Good call @goldneagle !
Those upgrades definitely make the DUCKW model a lot more realistic. I wonder if the co-pilot was manning a .50 while they were "headed in" for a landing. According to a quick lookup on the web, about one in four DUKWs came with a .50-caliber Browning heavy machine gun on a ring mount on the right side. There is also a hand mounted search light on the drivers side of the cockpit. There is a small propeller under the back bottom if you have a way to create one...
There is still a lot of detail work to do.
