My new to me 002A's
dangier
Orange, VA
OK guys, need a little advice here. Installing a checked out ip that storeman did for me (thanks storeman). In completing the spill tests, I keep coming up with the timing being 1 1/2 lines under the pc mark. Currently have a #12 button installed. I do have a #1 button available. Question is-with the flow stopping under the pc mark as viewed in the window, do I need to increase (like #13), or decrease (like #1), the button. It does run as is, but sounds different.
David
Jimc
9
Mullica, nj
Off hand i dont know which way you need to go but you do need to move 3 button sizes. Each step in size mives 1/2 mark
dangier
Orange, VA
This ip came off this unit. Ip had a #1 button on it....
My error-looked at my notes and it belongs back on the other unit.
dangier
Orange, VA
Ok, I think I have it now. Mep 002A has a #1 button installed. On a spill test, the flow stops 1 1/2 marks under the pc mark. Reading the TM, this means three button sizes too small. I need to up-size to a 14 or P button.
Anyone have a 14 or P button they wish to part with?
This seems to me that this machine was not timed right from the get-go or has been messed with. The ip and button came with this machine. Not surprising.
storeman
52
Mathews County, VA
David,
I wondered when you said #12. I thought #1 was with it and went back to you. But, now that you have flow timed, you know where to go next. Sorry, I have no 14 or P buttons.
Jerry
dangier
Orange, VA
Jerry,
The #14 button was on the pump I had switched to get the second unit running. That was also 1 1/2 marks under pc when I checked it yesterday. Unit ran and carried a load very well.
Is Ambac the best/only source for buttons?
Thanks,
David
Isaac-1
51
SW, Louisiana
There also is / was a seller on ebay that offered them at a discount below what Ambac sells to the public, as I recall it is a fairly misleading ad with a picture of pump, but selling just the button
gimpyrobb
dumpsterlandingfromorbit!
27,791
783
Cincy Ohio
Is this the 1.09 pump that had the #1 button?
