My new to me Gama Goat
Another Ahab
4,808
Alexandria, VA
Man, you are BOOKING along there. Sounds like the RPM's were wound up pretty tight, but I couldn't catch which gauge on the dash was a tach:
- What kind of RPM's were you running at that road speed?
AMGeneral
116
Connelly Springs, NC
I "think" the 3-53s are governed to 2200 rpms(?) Detroits just sound that way normally.
As to the RPMS,no idea,Gama Goats never had tachometers,(to my knowledge anyway).
Sorry for the shaky video,evidently I have a tire out of balance on the tractor of the Goat.
Gamagoat1
36
Kiowa, Colorado
2800 rpm
AMGeneral
116
UPDATE....
Since I am off for Christmas and New Years,I have some time to work on the trucks again,yesterday was finishing the brake rebuild on the M54A1, today is alignment of the Gama Goat!
I concluded that it had 3 major issues...
Drivers side front negative camber/caster angles.
Passenger side front negative camber/caster angles.
Passenger side front toe out.
The Gama Goat uses shims on the lower control arm to adjust caster and camber angles,and a standard threaded tube w/locking nuts for toe in/out.
In my case I had to remove several shims from both sides to adjust caster/camber angles,and them measure and adjust toe in afterwards.
The right front was 1/4 inch toed out with all other steer tires in the straight ahead position,before I made any adjustments.
SCSG-G4
PSVB 3003
5,398
3,485
Lexington, South Carolina
Don't know about RPM's but I remember Bill Strozier drove one up from Charleston to Ft. Jackson on a monthly basis back in the early 1980's, and he was keeping up with traffic (65 MPH speed limit).
wsucougarx
Washington State
Any chance you can get a measurement for me? Just wondering what the distance is from the top of the engine cover to the top of the hardtop. I need to see if it's enough clearance to get in my garage. The cab soft top frame just clears the top of the garage.
AMGeneral
116
Sorry it took so long Mike,I just now saw this post.
From the engine cover to the top of the hardtop is 21 inches,granted mine has the older style engine cover with the square corners vs the rounded ones.
mkcoen
381
Spring Branch, TX
I thought the rounded ones were the older style.
mkcoen
381
Spring Branch, TX
Well,time once again to bring another thread to a close,
I loaded the M561 Gama Goat on a shipper this evening,bound for it's new owner in Arizona,hopefully he will enjoy it as much as I did the short time I owned it.
Wow. Lot of time and effort (and tires) went in to the 14 months you had it. I was hoping it might be re-united with it's brother at a show some time. I guess it'll be closer just not with someone I know.
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Hopefully the ol' goat's new owner is a member of the site? AZ has perfect terrain for a goat to romp around in. Thanx for your help along the way AMGeneral.
