gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 791
- 113
- Cincy Ohio
What he said.
Gotcha, makes sense. The hose is rated for air pressure, it has steel woven into it. Hope it lasts.Use either copper or stainless steel braid ptfe lined air hose for the first 3 feet or so directly out of the compressor. The heat from the air will eventually destroy hydraulic hose.
Thanks man, really appreciate it. I'm really slacking on the pics, I'll get some detailed shots up soon.I am totally blown away by the detail put into this build so far!
I had to delete the chain drive off of mine and it's still geared very low, engine was at idle trying to pull a a stuck 20,000 lbs tractor, rpm's never changed.I have a very similar winch for the rear of my deuce, and I was planning on making a chain drive for it and mounting it right behind the cab, does 1st gear offer enough power to pull you out of a stick situation? I was planning on a double roller chain with whatever size sprockets I end up needing.
Sure can, I'm headed to the shop today, I'll snap some pics.Could you post some better pictures of the boot guards and the winch mounting and around the winch?
I built the column, it's just a piece of 1 3/4" tubing with the common 3/4" steering shaft material as the actual steering shaft, bushings where used to keep the shaft centered and spinning smooth.What / how did you mount the custom steering wheel? I have to do something for more space for a plus sized operator as I am no longer 20 and skinny. Mark
