- 290
- 20
- 18
- Odessa/Texas
Looked up NSN: 6680-00-933-3600Normally, the meter doesn't go back that far. Non standard meter?
I will give that a try, thanks.Do you have any file folders? That will also work. They should be a little thinner than the thin plastic cutting boards.
Never knew these were a thing, if the plastic cutting boards don't work out. I might order a set.How about brass shim stock? you can get it in various thicknesses
