Need advice on my M886 Ambulance
jhyatt7
texas
Got her running good, turned her off to change a brake line, and now she has no power, no headlights, no interior lights nothing at the ignition. The battery is good an fully charged. Its acting the battery is not even installed. Everything is tightened??????/? Where do i start?
msgjd
3,170
upstate ny
above answers are correct, and also add to your checklist to remove the retainers to unplug the blocks on the firewall driver side. The heaviest connection in there leads to the amp gauge and feeds the whole system. I have seen this connection corroded, or overheated and spread loose, or completely burnt. Check it out, clean and lube all those connections in there while you have it apart. I bought an M890 years ago from a DRMO claiming engine was seized for it would not turn over. Imagine their surprise when I unplugged and cleaned/tightened the connection and I drove it onto my trailer.
