Need advice with parasitic battery drain
Tanaga
Palmer, AK
I thought you said you checked the alternator ? If it is the alternator it is probably the diode pack. The diodes go bad and allow a "back flow" of current. Very common problem with GM alternators.
Well i I thought I did but I may have had my multimeter on the wrong setting. Figuring out how to use that is half the battle.
redline300
Ocala, Florida
What is the normal amp draw on an M1009? I had a parasitic draw. Found it to be the Alternator wires not being connected fully. Since fixing that issue....what is the normal amp draw supposed to be at?
rustystud
3,374
Woodinville, Washington
If you have a working radio, then the amp draw should be around 0.03amps to 0.05amps . Any more and your loosing power from something, usually the alternator diodes.
