Need bolt size and length for NHC250 oil filter conversion kit.
goldneagle
868
Slidell, LA
I purchased the oil filter converter listed for the Cummins NHC250 engine. The kit had everything except the center mounting bolt. The instructions say it could be a 4", 4-1/2", 5", 5-1/2" , or 6" depending on the engine.
I was wondering if someone that installed it already know the proper bolt size.
swbradley1
Modertator
1,590
Dayton, OH
I wonder if you have to try different bolts with the adapter to see which one fits correctly for the one you have. If the instructions say that it could be different sizes then that means there are different 250 engines (at least with regards to the filter).
goldneagle
868
Slidell, LA
Actually there is no NHC250 engine listed in the instructions. These adapters fit different engines that use a large canister filter. I think that is why they don't include the bolt.
I was just trying to save from buying 5 different 5/8" bolts for the adapter and testing each one. i am assuming that (since the adapter is listed in the forum as a part for the NHC250 engine on the spreadsheet) some members have upgraded to it. :grd:
indy4x4fab
Banned
1,711
41
indy, indiana
We ran in to this problem with a buddies m923 I think we end up using a 5'' grade 8 bolt and put a half inch of small diameter flat washers on it to make it a 4.5'' bolt, cost was like 3 dollars from T.S.C.
goldneagle
868
Slidell, LA
I appreciate the info. I will get a 4-1/2" bolt and a 5" bolt just in case.
I would be concerned with having a stack of washers on there. More chance the bolt could come loose from vibration.
indy4x4fab
Banned
1,711
41
indy, indiana
not if you use brake parts cleaner and remove the oil from the surface of threads then lock tight it in.
swbradley1
Modertator
1,590
Dayton, OH
You can never have too many bolts around of the Grade 8 variety. I would get one from Fastenal in each length.
seano11
102
Edmonton Canada
Maybe you just got a part's guy that didn't bother asking you which one you wanted? I went to both cummins and napa. Both had the 2 different one's but cummins was cheaper
doghead
4 Star General /Moderator
1,168
NY
How about posting the napa and cummins numbers, to make this thread even more helpful to others.
goldneagle
868
Slidell, LA
From the spreadsheet on this site:
NHC250 Spin on oil Conversion NAPA FIL 4067 WIX 24067 FleetGuard 300923S
On the top of the box: (NAPA) 524067 Instructions say: WIX 24067 KIT
Asking for 5/8" -18 UNF -2A Grade 5 bolts
Draco-87
bakersfield,ca
I just received the fleetguard oil filter adaptor for my 923, but the # on it is 3300922S. Is this the wrong one? and could it be for the 800 series?
Scar59
41
Mt. Eden, KY
I stock and sell the Baldwin kit. It fits all NHC 250s and has the correct bolt included. Also includes a Fleetguard LF670 filter.
Check the classifieds
JC
