Need help!! Found the leak!!
RIDDLE1
Americus GA
Ok so I had an oil leak on the front of the motor and ordered a new timing seal and gasket to fix the problem. Well today I pulled the front of the truck apart to replace the part an found this.
I noticed that the dampener was loose when I went to take the belts off. The bolt came out by hand after I removed the retaining plate. My question is what caused this to crack? Was it because it was loose or just broke for the **** of it? I have a buddy with a parts truck I can get one off of, I think.
Beerslayer
53
Tualatin, Oregon
OK, I am going to make a W.A.G. here.
If the bolt had any play in it, when the motor was revved it could have given a little more sideways snap/yank to the balancer that it wasn't designed for.
Either that or your first guess was right, that it just broke for the **** of it. Say metal fatigue, but I would lean towards play in the pulley as a contributing factor.
Warthog
227
OKC, OK
I have a spare dampener from a parts engine if you need one.
It will fit in a flat rate box.
Memphisdoug
Memphis, MI
Just to nit pick here - it's a damper not a dampener. Dampers take away vibrations. Dampeners make things wet. Just something one of my professors once told us in class
tie6044
42
Blaine, MN
Isn't it also called a balancer? I had a local guy that had the same problem, his actually came off and messed up some other things like the cover and a gear behind it. He was able to get it back together with some used parts I had.
RIDDLE1
Americus GA
Well I thought I was going to finish it. Turns out this may be a two man job. I need someone under the truck to hold the bolt on the timing cover. Oh well.
Hooty481
Russell County Kentucky
you are the second person in a week that i have seen with this problem. Aaron had the same thing happen to him. he came and pickup a 1 peice harmonic balancer from me last week. not sure how he turn out yet though. he has a thread on it. i'll try to find it and post the link
to it.
rrrr
Missouri
Where is soldier "B" when you need'em aua
Its always a pain when you need an extra set of hands.
3dAngus
101
Perry, Ga.
Would someone be subject to putting a crowbar or prybar in there to tighten up a gen or other asset on the belt?
If so, that would explain it.
RIDDLE1
Americus GA
That could be the case. I have seen people do worse. I looked the damper over and could not find any marks that would suggest it was beat on or used as a lever. Who knows?
I do know that as soon as I pick up the new one on Thursday this will be a problem of the past!
1,168
The 361 series TM calls it,
5 PBFZZ 19207 10935278 PULLEY AND DAMPENER
