Need help M35A2 flywheel to crankshaft bolts
doghead
4 Star General /Moderator
1,189
NY
If you look up the NSN in the parts TM, then google that number wit "parttarget" in the search, you will get all the specifications needed to duplicate it.
doghead
1,189
NY
Keep in mind, these are not a "normal" bolt.
Notice,
Locking FeatureDistortions bearing surface of head
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Also, in case you didn't know, the bolt holes are not spaced equally. One is offset, it took quite a while to line up the first time I did one.
doghead
1,189
NY
ARP has this type of bolt.
