joshs1ofakindxj
- 131
- 43
- SW PA
Paperwork says I have a 1954 Kaiser-Jeep M35A2, recently acquired in NY. From my pictures people seem to think the truck is closer to a 1970 vintage.
https://fbcdn-sphotos-a.akamaihd.ne...648755343_755350342_21019041_1500798431_n.jpg
(See attached image)
1. Weight/Dimension data plate missing off of dash - I need this with the weight of the truck printed on this so a mechanic can read it and I can get my truck titled in PA. I've been looking for this plate for an M35A2 with winch model with no luck. Please advise on where to find a plate that has the proper truck weights and I can stamp with my VIN/registration.
I tried Memphis Equipment, Saturn Surplus, - no luck, no one is answering and mvdataplates.com and on ebay I see a plate listed as for M35A2 W/W but the picture shows one that is M35A2 Wo/W - might try and contact them.
2. Front tire wear is heavy on the outsides of the front tires, with the passenger side being worse. Seems normal from searching. I'm going to check bearing/knuckle wiggle but what are the toe in measurements for the front end so I can check alignment?
3. Fuel gauge reads empty when power off, and all the time when the power is on it reads full. Most likely cause before I go chasing wires?
Thanks.
Thanks.
