New 85 M1009 24V 6.2L owner starting issues?
GunnyM1009
530
Roanoke/Alabama
I just bought It about two weeks ago. The Negative on the front battery goes to the lower block on the firewall the positive on the front battery goes to the negative on the rear battery and the positive on the rear battery goes to the top block on the firewall. My skill set is moderate I do not claim to be a mechanic but I am usually able to figue things out on standard vehicles but this thing has got me stumped the things I have already done would have fixed any issue with a standard 12V gasser
GunnyM1009
530
Roanoke/Alabama
I am getting 12.54 from the rear battery and 12.03 from the front battery 12.03 from the driver side alternator and 12.54 from the passenger side alternator
Warthog
242
OKC, OK
12.03v after a recharge tells me a bad cell in that battery.
FMJ
37
Las Cruces, NM
Can you connect the meter and have your wife try to start the truck? and note the voltage during the attempt to start
FMJ
37
Las Cruces, NM
Ok, do it again, this time on the positive post of the front battery to the same engine ground you used before
cpf240
Free in Northern Idaho
ok when she hit the key it jumped down to about 16 so what does that mean
That sounds like too large a drop to me. I would run the test again, taking a reading across each battery in turn. This is sort of a poor man's load test. If one drops much more than the other, then I'd suspect that battery has a bad cell.
GunnyM1009
530
Roanoke/Alabama
Ok it was a bad front battery whoooooo got him going again hooked the jumps to the front battery and he fired up I did not think to just change one battery and apparently the two smaller ones from the other vehicles just did not have enough juice
Warthog
242
OKC, OK
Without truely knowing the condition of your batteries, full charge and load tested, we are just guessing on how to help you.
Warthog
242
OKC, OK
And a bad battery strikes again. That is why we always say to check your batteries first. Never guess/assume they are good.
