DB556
- 129
- 43
- Ambridge, Pa
Well first I had a 3000lb stick crane, then a 8000lb knuckleboom, now its a 6000lb stick crane again, so crane time for a new thread,
old thread https://www.steelsoldiers.com/threads/decision-on-a-knuckle-boom-crane.193569/
In my last set of mods, I got a 6000lxr Stahl crane installed using the knuckle boom, used the stahl to remove the hiab.
built a over build dumb bed hinge, and swing and stow hydraulic out riggers, so I can have the bed dump.
I've started getting my disc brakes, and hydro max master installed along with a hydraulic clutch cylinder.
Reason I'm going with hydraulic clutch is I want the pedal hanging under the dash. So I ditched the stock pedal brackets and moved the battery cables, and have a smooth frame on each side.
So I can get a set of 36" tool boxes on either side for gear and even more batteries 5 or 6 haven't decided yet I know I'll have 4 batteries for the 24v systems; starter, gauges/fuel pump (till I migrate them to 12v) and hydraulic pump for the crane and my big 3000w 24v power inverter. For the 12v side that will be the lights, turn signals, cab accessories, brake controller, and diesel cab heater.
And since a picture is worth a thousand words, have some pictures.
First is just a random deuce I saw while going to work.
The using the Hiab to move and mount the Stahl, I pulled some 3x4x1/4 tube through the bed with a hoist, welded it in place then drilled down through the tube and welded in some section of 2" round bar that I drilled on the lathe too 1" ID.
