ODdave
- 41
- 0
- lansing michigan
sorry, i tried to locate the exact one i bought, but can not find it for some reason. there are others on there though
What rod end are you looking for?Japickar if you don't mind me asking where did you find the rod end? I'm trying to set the same thing up thank you for any help. Any tips to I'm also new at this lifting ordeal. Thanks again
I don't mind a little slop but the steering block IMO is not enough correction for the 6" lift. I really wanted to do crossover in the first place - I just needed an excuse to do it.I have the steering block on mine with a 4" lift and it has proven itself to be fine for what I have . . . of course there is play in the wheel a little bit but its an old pickup truck, what do you expect.![]()
If you are referring to the crossover steering arm you can find it at Total Performance's store on ebay.Japickar if you don't mind me asking where did you find the rod end? I'm trying to set the same thing up thank you for any help. Any tips to I'm also new at this lifting ordeal. Thanks again
That makes sense, thats what I would do as well...good luck on your build![]()
