New high back seats???
TheGreatMidwest
the middle of Ohio
Has anyone installed the older MRAP style high back seats or the HEMTT seats in their HMMWV? Would be especially interested in anyone's suggestions about upgrading the rear seats in an m998 to high back seats. Thanks!
TheGreatMidwest
the middle of Ohio
HEMTT seat, air ride shock absorbers, adjustable
The HEMTT seats sound like they have some nice features-
[SIZE=-2]DUAL HEAVY DUTY SHOCK ABSORBERS FOR AIR RIDE, DUAL LOCK TRACKS; RIDE CONTROL AIR VALVE LOCATED IN FRONT OF SEAT; ADJUSTABLE 2 IN FORE AND 1.5 IN AFT AND 3 IN VERTICAL.[/SIZE]
NateM1123LA
Louisiana
I can get them for you tomorrow...I have done about 20 and its not hard. Have primer and paint ready to cover the bare aluminum when you remove the old drivers base.
Late question to this thread sir! In your installations did you ever come across studs that were too short to go through the plate and battery cover? My commander kit seat studs arent long enough and i'm thinking it was meant for the back maybe? I'd rather not weld new bolts as i just got this kit.
Mogman
10,455
Papalote, TX
I used an air chisel to remove the OEM M998 seat base took all of 5 minuets, bolt the new base pieces to the new seat base and get it positioned and drill a few holes, bolt them down with a few screws then remove the new base and drill the rest of the holes and then bolt everything together including the bottom support plates, then bolt in your base and seat, should take no more that a couple hours all together.
There is also a tab that mounts to the back of the battery box to lock in the new Commanders seat base.
sf1954
Richmond, Va
I used 4 prong T nuts for to solve that problem. I ground off the prongs and screwed the T nut onto the seat threads thru the plate and battery cover. It has worked for 2 years.
Mogman
10,455
Papalote, TX
One seat has longer studs than the other, try the other seat
Mogman
10,455
Papalote, TX
the other seat is the driver seat, it has the big black base attached already, (came that way) are you saying I should un-attach it and try that one on the passenger side? Thanks!!
Well you can measure the studs, if it was a new boxed seat retrofit kit one of the seats should have longer studs, if that is the one you are trying to install on the Commanders side then something else is wrong.
Mogman
10,455
Papalote, TX
The Commanders studs measure about 1 1/4" the driver studs are about 3/4"
NateM1123LA
Louisiana
thanks for all the info, I removed the other seat from the base and both seats have the exact same stud length and model numbers on the seats so idk. Basically the back studs don't reach through at all. Had no idea there were different stud lengths on these.IMG_9609.jpg
Action
1,564
East Tennessee
So, 2 front studs go through but the 2 rear dont? There is a dip towards the rear of the battery cover. Did you drill the new mounting holes yourself for the seat studs?
Mogman
10,455
Papalote, TX
Those look long enough, if they are 1 1/4" they should work, the "new" seat base is nesting flush with the old battery cover yes?
maybe some kits just had two "Commander" seats, probably having the longer studs would not hurt anything and it would simplify things a little
NateM1123LA
Louisiana
this is how both fit on the plate, no room for the battery cover on the back with this stud height, they barely poke through not enough to get a thread on. Am I doing something wrong? Holes were pre drilled in battery cover already.seat plate.jpg
Mogman
10,455
Papalote, TX
back the camera out, it almost looks like the plate is backwards let me run back to the shop and see if I can find a plate.
Mogman
10,455
Papalote, TX
This is what it should look like, minus the rust LOL
Not sure what is going on with yours
