- 1,812
- 1,513
- 113
- Orlando, FL
1. The breaker box does not mount anywhere. You only put it on when using the crane, and then just roll it up and store it with the rest of the cables when not in use.Its been a while since i worked on the truck, have a bunch of parts odds and ends to install. did not get the air bags on yet, but I did get a surprise find part from Gov Planet. Light Material Handling Crane, new in what was left of the crate. 3 sold i was lucky enough to buy the last one. Its a heavy bugger to install by yourself, but i did manage to get it together. I stopped this summer when it was hot and today decided i would finish. Everything works here are my questions.
1) i can not find a picture or diagram of where the Breaker box mounts. I assume it stays on the outside of the truck all the time and you just unplug the cord
2) does anyone actually use the ratcheting pivot or just pull the pin out so its free to rotate? i have both the long and short handle.
Pictures tomorrow when its light outside.
2. I use the ratcheting pivot handle, and switched it to the long handle. I feel it's pretty important, as it allows you to positively control the swing of the loaded crane, as having it free-swinging would not only be dangerous, but physically difficult if it were really heavy. When the crane isn't in use, I put a bungee cord lightly around the ratchet handle and the crane post, to keep it from swinging while the truck is driving, or else it will slowly ratchet itself around (and could do something like puncture your cargo top and stick out into traffic).
