New m1009 Floors via extreeme liner
Red_506
Roseville, CA
Great job SGTskully! Cannot wait to go there myself. On your third batch of pictures # 8 of 8. I see a gloss black piece of sheet metal runing accross the floor. What is the pupose? I do not have on my 86 - 09. :shock:
That is meant to protect wires for antenna and power cables when radios are installed.
K9Vic
Fort Worth, TX
THey are the stock military mounts, I just cleaned up the rust reprimed them and then sprayed them with Rustoleum Hammered paint.
My truck is a 1984 and the seat mounts are not the same, what year is yours?
And thanks
Those are seat brackets for the civilian K5, not sure why it would have those from the factory. May have been an in error or near the end of a run and those were available. I had an 86 and they were the same as my 84 M1009 with the adjustable sliding brackets. I do have a set of those brackets on hand from a civilian K5 as extras from seats I swapped, but that is the first I have seen them in use on a M1009.
Mine and those seen in the picture do not have any sliding rails to adjust the seat, so is there any front/back adjustment? There was no sliding adjustment on the seats or brackets I had from the older K5.
SGTskully
Gothenburg, ne
I am the second owner of this truck and the prev owner did not have it very long. It came from Ft Lewis and the Wasau USARNG had it also. It does have front back adjustment but still had the old style washer pump and motor so it was a contract gov vehicle.
cpf240
Free in Northern Idaho
Hmm... is there a source for this info? I've wondered what it is for as well. Per the -20p TM, it is listed as:
4 PBOZZ 11862 474022 FRAME SECTION,STRUC 1 UOC:209
