- 18,154
- 27,274
- 113
- Burgkunstadt, Germany
I don't know how much you know about working on generators, so I will warn you to disconnect the batteries, or at least take the negative clamp off the right side battery. Where you will be working on the fuse mod, is almost directly over the MT4, Ammeter shunt. It is directly hooked to the batteries. Should you drop a wrench, or something metal on it, better have your sunglasses on. The potential to short out the wire harness is great there. There is no fuse or circuit breaker between the battery and the shunt. If this is old hat to you, then just laugh and carry on.
