- 2,011
- 73
- 48
- Orlando, FL
kswagg720: Welcome to the Green Iron Laughing Academy!!! ![Banana :naner: :naner:](https://www.steelsoldiers.com/images/smilies/banana.gif)
![Jumping :jumpin: :jumpin:](https://www.steelsoldiers.com/images/smilies/hop.gif)
![Driver :driver: :driver:](https://www.steelsoldiers.com/images/smilies/driver.gif)
Thank you for your service to our country!! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm thankful you've spent some time researching M1009's before buying one cold. Here are a few tips. Let me preface them by explaining that I bought my M1009 9 years ago. It's been an interesting journey, but one I'm thankful I embarked upon. I use my M1009 as a daily driver when I need some 'diesel therapy' and don't feel like driving my CVPI
- Join a local MV club. Find someone that owns a CUCV that would be willing to help you inspect the one you want.
- Keep reading. Keep researching. Read the TM's. Read the Stickies. Research part numbers. Familiarize yourself with every major system on these trucks. They are not complicated, but they do take time to understand.
- DO NOT SELL YOUR CURRENT DAILY DRIVER UNTIL YOU FEEL LIKE YOUR M1009 IS RELIABLE. EVEN WHEN YOU DO FEEL LIKE IT'S RELIABLE, DO NOT SELL IT! I've had a few experiences where AAA was my friend, and the flat bed truck driver did a great job delivering my M1009 to my driveway or my mechanic's shop. Having my CVPI meant that I still had transportation while my CUCV was down. Some parts are getting rare and are online order only, or have to be ordered from the main warehouses by Advance Auto because they don't stock the parts in the stores as much. Keep this in mind when working on your truck. Another example - I just found out that the brake lights aren't working on my CUCV. I don't have time to fix it right now due to work, but I still have transportation.
- Check the rear axle for wetness. If it is wet, there is gear oil leaking out of the axle seals. The gear oil can soak the rear brake pads, effectively disabling the rear brakes. This can be repaired by any shop that has experience with Dana axles. It's not a big deal to repair but it could be negotiating tool for you to get the price a little lower.
- Don't focus on making modifications right after you buy the truck. Get to know it first. Here's a thread that will help you when you get to that point. http://www.steelsoldiers.com/showthread.php?146375-Cucv-upgrades
- Sound insulation is mandatory if you plan on installing a stereo. These trucks are resonating chambers (drums) with the windows closed. They are LOUD. Insulation will also help keep the truck cooler after you install the A/C.
WatchDawg - My M1009 was converted to 12 volt so the factory A/C system would be easier to install. The driver side alternator was replaced with an HR-6 compressor with the factory brackets. The 12 volt conversion has allowed me to use the bus bar in the passenger compartment to run accessories. I have a dual band amateur radio hooked up to it. I built a 12 volt dual outlet power box with a switch and a 15 amp blade fuse so I can power fans and charge my cell phone from inside the cab. The 12 volt conversion has also made it A LOT easier to replace the starter on my truck.
![CooKoo :cookoo: :cookoo:](https://www.steelsoldiers.com/images/smilies/cookoo.gif)
