llong66
- 2
- 0
- kokomo, In
I have recently built a new 6.5l NA motor. I am having some smoke out of the pass. side of the motor and a slight tick both at idle and while under acceleration. The smoke is slightly bluish in color and is most noticeable while under acceleration. When I let off the accelerator, the smoke seems to go away. The motor is 100% rebuilt, all new parts, the block was magnifluxed, the heads are new, new cam,lifters, crank, rods, pistons, etc. The only reused parts are the push rods and rocker arms. I replaced the CDR valve, all new filters, new Bosh injectors, etc. I am at a loss as to where to took.I marked the push rods so I am sure hey are in correctly. Does anyone have an idea of where I might look?Thanks much!
Greg
Greg
