new owner of a m448
Tracer
14,380
Hawthorne, NV.
Good find!! Here is the TM for the M448. TM 9-2330-213-14&P Keep us posted on your progress.
Buffalobwana
179
Frisco Texas
If you decide to tow it home (which I have done uneventfully on numerous 4-8 hour trips) here is an idea.
You say you will replace the axle anyway. If time situation and funds permit, go ahead and bring it with you. If you get in a jam, you or a garage can install the new axle and you are on your way.
You will be money ahead of the game instead of having to fix an axle you don’t want. Since you will be changing the axle anyway.
Does the seller have any info on bearing condition?
ArmyRover
FT Gordon
That's not a bad idea wish I would have thought of that a couple weeks ago lol. Seller said he towed it about 50 miles no issues and all seemed fine. He doesn't know the age of the tires etc.
Tracer, funny I found that one when I first started looking for info on mine.
Scrounger
69
Southern, Maryland
The lunette on that trailer has already been flipped. If I were going to tow it, I would double check the bearing grease, if it looked good go for it. The only other thing I would take is a couple of mounted tires with the appropriate tools for the ride. That would be to keep Mr. Murphy from making an appearance.
ArmyRover
FT Gordon
Was hoping not to buy more tires for it as I don't plan to keep the axle. I want to swap it out for a dexter axle in a pattern that matches my truck and has electric brakes. Need to read the TM on servicing the bearings.
Lug nut size is 1 1/2" correct?
ArmyRover
FT Gordon
If anyone along the route between Fort Gordon and Wickes AR has any good spare tires they are looking to sell cheap I might be your guy. Let me know
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
ive got an 11.00 in memphis not on a wheel. I don't have any 9.00s here I don't think. Memphis equipment would have some if you needed em really bad
Buffalobwana
179
Frisco Texas
Sure reduces the pucker factor when your bearings are greased and you have a good spare. Every little noise doesn’t scare you as much!
I carry a squirt bottle of 50:50 acetone and ATF. It’s the best penetrating oil I have found yet. Better and cheaper than Kroil. Also, I think the threads on one side (right?) are left hand threads.
Good luck!
rumplecat
246
North West Arkansas
Towing is going to be scary, those are 50+ year tires on the trailer, I trailer ed both of mine! Something else you need to check, is the top of the trailer is a separate sheet of metal, they tend to come loose from the side section, if this happens in the front,which it usually does, the wind from towing/trailering will rip it right off! Carry an extra two strap to wrap around the front of the boxIMG_2131.jpgSAM_0687.jpg71QSCI17085003A.jpg
Buffalobwana
179
Frisco Texas
That is a good idea. We had a horse trailer when I was a kid. Had been hauling horses in it for years. One day the top peeled right off. No horses in it luckily.
It happens.
ArmyRover
FT Gordon
May have found a large enough trailer to get the job done should know in the next day or so. If that's the case this weekend it comes home.
