New Project
fsearls92
157
Charleston, SC
Pull the injectors and if you have a bore scope look down in the cylinders, could be full of water, oil, etc. if clear pour marvel mystery oil down the cylinders and let it sit.
Elk1111
493
Las Cruces NM
Thank you. I’ll get to working on that. I believe the engine is hydro locked because the oil level seems too high and there was oil coming out of the fuel shut off cover when I opened it.
I’m assuming I have diesel in the oil pan and will find out more when I drain the oil.
