Keith_J
- 1,327
- 113
- Schertz TX
Heat is your friend on stuck fittings. Don't round off nuts. Now, on the no fuel issue, track the governor linkage to where it enters the injection pump, that lever must move freely. If it doesn't, it can be fixed without pulling the pump. But it takes a ton of patience and knowledge of how the injection pump works. Plus a small dental mirror to assure the control collar pawl is properly engaged. If not done right, you can have a run away engine.
