New to the boards
ford
Houston, Texas
I'm Ford, from south east Texas. I found my way over here from a SurvivalBlog post. I have always loved the M35 (and MVs in general). I have been toying with getting one off and on for a few years now and am now more serious about it. So here I am looking for information, trying to figure out what I will be getting myself in to. There's no convincing left to do...I just want an idea of the trouble I am in for.
I just wanted to say hey and thanks for having me!
1,131
Welcome to the site. There are a few guys in your neck of the woods with MV's.
If you're considering a deuce, the attached article is a great primer.
ford
Houston, Texas
Thanks for the doc clinto. Ill give it a good read. I have never been in or ridden or driven one before. Just seen them from the outside so I'm curious about that too. Hopefully I can find someone that will take me out for a spin. I'm also trying to figure out if I want a 2.5 or 5 ton. Im pretty good with vehicles but these are ones that I just don't know much about.
ford
Houston, Texas
So I spent yesterday and most of this morning looking for some info but I couldn't really find what I was looking for. Basically, I'm trying to decide between a 2.5 ton and a 5 ton. I see the differences in the size in pictures but I was trying to find some discussions on the differences, pros, cons, etc.
As far as my needs go, it will mostly be to go have some fun in as well as an emergency vehicle for me and my family. I intend to use the back for cargo. I will want to add some additional fuel storage. Will be interested in running a handful of comm devices (not sure exactly what just yet...thats a totally separate area of investigation on my part). Interested in a PTO, singling, larger than stock tires, etc. I am interested to get about 1000-1500 mile range out of it if I can.
So that being said, I have only seen pictures/videos of the 5 tons in action but don't know any differences other than the axles and the apparent size of the truck. Any information would be great or just a shove in the right direction of a thread or something.
Thanks in advance for the help!
*edit* If I put this in the wrong place, let me know and I will re-locate...I just wasn't sure which area to stick it under.
krall
shippensburg PA
welcome, first off, and I would say a deuce would do the trick, 5 ton is not much different just size and fuel suckage. besides 5 ton is more for pulling and much more heavier weight, hence 5 ton, if your not looking for heavy hauling and more for just back up, m35A2 sounds like it fits the bill.
runk
65
Houston, TX
I think you've already identified the big difference - size. 5 ton's bigger size and weight means CDL, commercial insurance, gigantic (instead of merely huge) parts, 32 point u-turns (instead of 16 point), worse mileage, and so-on. Parts are equally available. Many of the 5 tons already have some of the modifications you can add to a deuce, like power steering and larger tires (11.00's).
Also think about where the truck will live, and what restrictions you might have. As far as Texas is concerned, the deuces are the same as a big pickup (although some deed restrictions may call out lower size limits), a 5 ton is clearly a heavy truck under laws and regulations.
One of the other members here has said he kept a 5 ton brake drum when he sold his 5 ton, and whenever he feels the need to buy another, he just goes out and tries to pick up the drum...
Of course, all of the above is not to say I don't want a 5-ton ! (Or even better, something bigger like a M920.) But, I can't even sort of justify a 5 ton, as there is nothing I would do with it I can't do with my deuce.
ford
Houston, Texas
Thanks for the info. I was thinking the same thing about size. I didn't realize that the 5 ton would be classified as a heavy truck so I definitely don't want to go that route. Looks like it will be the M35A2 then. Now I just need to take a ride in one and learn more about them...and find one!
I recall some of the pictures I saw of members doing work to their 5 tons and remember thinking that I would need to get a fork lift too.
Im also not sure where I'm going to store this thing. Im moving at the end of the year and not sure where too so I may just find a storage unit that will hold it for now.
1,808
Welcome aboard. I think the deuce will fit your needs nicely. Haha, it is I that keeps a 5 ton brake drum in the yard just for that reason. I just went to the GA rally in my deuce. 3 trailers (small ones) on the way up and one on the way back. I left with 205 gallons of fuel and returned with about 20 in the tank. Trip was 610 miles each way + probably 50 or 75 rolling around miles. Look at storing 250 gallons on board to get the range you want. FWIW, I burned used motor oil cut with diesel fuel.
ford
Houston, Texas
Thanks guys!
nofearnohope: I just noticed today that I missed the rally last weekend. Better late than never I guess. I have already marked my calendar for the next one though :)
Recovery: thanks for that bit of info. I had read others reporting 8-10 mpg but I guess with 1-3 trailers, 7 is pretty good. I saw some posts on adding an additional tank but I don't recall seeing any about more than 1 aux tank. But then again, I haven't read the entire site yet...still working on that. Have you noticed any significant change in mileage when burning straight diesel and a used oil mixture?
My hopes are that by January or Feb, Ill have my Deuce in my driveway and by March have it off the jack stands :)
airmech3839
Augusta, GA
Welcome to the site. At any rate 5 tons are harder to find with multi's in them so most wont burn any fuel. Deuces are like driving a old "big" farm truck without power steering. I drive mine daily and love it. You can get better turn radius by putting lockout hubs on the forward rear axle and the front axle. It will help on fuel economy too if you are using diesel. I would look into spin on filter adapters and a either High quality 3/4" or 1" impact gun and good air compressor for tire changes and the such.
Again welcome to the site and happy hunting!!
airmech3839
Augusta, GA
If you plan to burn WMO or WVO then I would suggest adding a pyro gauge. The WMO burns hotter and you could damage a turbo(if installed). Also 100% WMO is like adding a fully loaded trailer to the truck when you hit hills and such. Loose alot of power on top end. Not as noticeable when cut with diesel.
KsM715
142
St George Ks
Welcom to the site. 5tons have power steering, less tiresome to drive. Look into the CDL thing, that can be state specific and dependent on how you register and use the truck.
Just to tease you Ill include pics of two of my favorite trucks seen on this site.
On side note, We have what, somewhere north of 20,000 members and no one has used the name "ford"? wow
ford
Houston, Texas
I know! I was surprised too! Who would have thought...everywhere else I go, that name is already taken...and by people who have no reason to! My name is actually Ford. So back off my username!
Also, those trucks are beastly! I love them. The tan one is what I would like mine to look like. Except for the tan. And I don't want to bob it. I guess I want to front to look like that one. But I want a hard top. Im still trying to decide between a boxed back or open. Im pretty handy with my shop tools and figured I could make sides and a top for the back that I can remove or open up if I wanted. I can make use of both an open cargo area and a closed in box. So many plans for my future Deuce!
I think I would need a CDL here in Texas for the 5 ton and I have actually already looked in to that for a previous project but decided that it wasn't worth the hassle.
nofearnohope
32
College Station, TX
You will need to get someone else to verify this, but I think if you register your 5ton as a former military vehicle, you do not need a CDL because it falls under the RV classification. Don't quote me on this, but I think this is true.
ford
Houston, Texas
Interesting. Even still, I think the comments about the size of parts and rarity have set my mind on the 2.5 ton instead. I don't need a headache on top of the project.
