mikey
- 39
- 28
- Lake Como, PA
I just picked up an 86 M1009 in what appears to be very good condition. I drove it home about 500 miles with no issues except Gen 2 light coming on. I'll test the high side battery and if that passes rebuild the regulator on the high side alternator ASAP.
I've read the -10 tm and will read the rest as necessary. Right now I'm reading as much as I can in the CUCV forum.
One issue I'm having is the alignment. From what I'm reading this could be a number of factors, but assuming its nothing major in the front end, is it true that most big name alignment shops (Jack Williams by me) should have no problem doing an alignment on the M1009 if I check it in as a K5 blazer?
Thanks!
Mikey
Thanks!
Mikey
