New2Me 1961 M37
Txsrooster
Santa Fe, Texas
I managed to get the truck started the other day, but when I turned the switch back to the Off position, the engine kept running. I used the secret "security" switch that the previous owner installed that kills power to the ignition to shut the engine off. So may be an issue in the switch. Funny thing is, that the starter will not turn when pressing the starter pedal with the switch off.
Txsrooster
Santa Fe, Texas
I have to wait for a few sunny days to recharge the battery. My shop is off grid and its been really cloudy these last couple of days so the power system is struggling to keep the lights on.
Txsrooster
Santa Fe, Texas
I changed out the master cylinder and successfully bled the brakes. The pedal no longer smacks the fire wall when pressed. I think I need to bleed them again as there is some sponginess to them. Getting closer to driving to the car wash for a much needed bath and vacuum.
Txsrooster
Santa Fe, Texas
Got the brakes properly bled, went to start it up, and it will turn over but will not start. I pulled one of the sparkplugs and it is dry, so not sure if fuel is getting making it to the cylinders. I turn on the electric fuel pump and see fuel in the filter leading to the carb, so pretty sure I have a carburetor issue. Luckily I bought a carb rebuild kit I guess. I did go ahead and order the Pertronix MV-161A to match the new coil I ordered. edited cause I ain't the gooderest speller.
Txsrooster
Santa Fe, Texas
Well...I ain't got no spark. New coil so Don't think that's it. I tried updating to the electronic system instead of the just replacing the points and condenser and that didn't fix it. I pulled the plug and had a friend watch as I turned it over and he verified no spark. @NDT let me know if you got some time to come take a look, as you might be able to see something I don't.
NDT
6,984
Camp Wood/LC, TX
The distributor caps are notorious for getting hairline cracks and then the juice jumps to ground right there. Do as G744 advises.
Txsrooster
Santa Fe, Texas
Well I got a chance to swing by to measure..I hope this doesn't mean my coil is bad... edit to remove duplicate photo
I used my multimeter and tested resistance from the positive to the center point on the coil and got "OL"...same for the center to the negative post. I get 12.4 ohms from the positive to the negative terminal on the coil.
G744
3,981
Hidden Valley, Az
You have to run the starter to turn the dist to open & close the points to get spark, and not with a meter. Just a jumper from ground to close to the HV end of the coil.
Txsrooster
Santa Fe, Texas
The new coil came in and I checked the resistance from pos to neg and it is also 12ohms, so makes me think that the old coil isn't bad. I guess next is the cap.
Txsrooster
Santa Fe, Texas
Well I won't pretend to understand it, but I installed the new coil (which tested the exact same with a multimeter as the old coil) and she fired right up. Drove it around the property for a bit to test the brakes and they worked beautifully. Next to tackle some of the electrical mess that is in there and get the brake lights working.
