augiedoggy
- 13
- 0
- Cincinnati Ohio
Hello to all, my 72 M818 (w/nhc-250) is in need of one injector rebuild or replace. Easy enough, take it to our local diesel specialty shop, but they can't find any info for it. A quick call to the cummins guru,Will Wagner, and he tells me where to find the fuel pump #s to give repair shop, still no help.
Memphis has a new injector for it, but it seems a little pricey. My concern is, are these injectors interchangeable? I have seen the production pn change in the TM. I'm pretty sure i've got the later style. Will was describing flow codes ect. and you don't want to mix them up and wipe out a cylinder.
Oh, by the way, my symptoms are.......one cool cylinder and excessive blackish/white-ish/fuel stinky exhaust. other than that it runs great!
Here is the numbers I have:
INJECTOR # 178A 8-7-17
INJECTOR PUMP NUMBERS:
FC4144-G
DR12089484
STAMPED IN HOUSING:
699
16610
Here is how I feel right now
Thanks for listening and I hope my newb-ness isn't showing
FC4144-G
DR12089484
STAMPED IN HOUSING:
699
16610
