noob
- 0
- 0
- West Virginia
hey there
got a 86 m1009
sometimes there is no drive in 2h/ 4h.
Will work fine then just will loose all drive out of the blue. Then, bad grinding when i try to put it into gear.
4low works great every time.
-Got it home from above described experience,
found leaking rear output shaft seal, fluid almost empty, and pull a piece of smashed plastic out of the T case drain. i thought that this somehow part of bad seal.
new seal, full fluid, drives for three days and looses high range mid drive again, fluid still full - seal still sealing.
I look around the internets, is this a problem with my shiftier fork? if so can people suggest some place to get rebuild kit for the 208 and new fork? also, advice on procedure would be very welcome.
thanks!
got a 86 m1009
thanks!
